Dave Oliver Posted June 2, 2009 Share Posted June 2, 2009 (edited) when using 3D vray displacement, i always get these jagged little edges. does anyone know if there are any settings that can smooth or avoid these? i dont think it is a problem with the geometry, it is all pretty clean. thanks edit: ok i guess i just needed to change the edge length value. it seems inevitable then that i use 50 bigillion gigs of memory to try and render straight lines using FRIGGIN SUBTRIANGLES. i Officially Suggest 3d displacement have an option that uses tessellation and smoothing Edited June 3, 2009 by dave5264 subtriangles Link to comment Share on other sites More sharing options...
