chow choppe Posted June 5, 2009 Share Posted June 5, 2009 hi all i was using max 2008 and vray 1.5SP1 till now but then i shifted to max 2009 and vary 1.5SP2 today one of my scenes which was quite heavy was rendering alright at 3600 pixels on max 2008 and vray 1.5 SP1 on the same PC but its crashes when starting to render inside max 2009 and vray 1.5SP2 what is the problem. now i cant even go back to max 2008 as i have saved it in 2009 version and 2009 is just not rendering it. please help how can i render it P.S i have diabled view cube so thats not the problem of crash. its crashing only when it starts to render and not while working thanks Link to comment Share on other sites More sharing options...
Nic H Posted June 5, 2009 Share Posted June 5, 2009 upgrade to sp3 i reckon, skip sp2. do you not still have 2008 installed? please tell me you didnt save over the old file?! Link to comment Share on other sites More sharing options...
chow choppe Posted June 6, 2009 Author Share Posted June 6, 2009 i still have 2008 installed. but i had thought i had overwritten the file in max 2009 but i realised that when max crashes it doesnt save the actual file but it makes a recover copy of it so my old 2008 file was intact and my recover file was 2009 format. But does that mean i should not shif to max 2009 and vray 1.5 SP2? even for new scenes? thanks Link to comment Share on other sites More sharing options...
am34012 Posted July 14, 2009 Share Posted July 14, 2009 I had same problem, somehow it mysteriously got fixed. Try this, open new file and merge everything from the other file and try to render. Another thing you can do is re-apply all materials, start with 1 vray material and apply it to all the objects in the scene, then render. If it renders, then it was a material problem. Also, it might be because of 32-bit system, so you might want to consider switching to 64-bit windows and max2009 if you haven't done so yet. Link to comment Share on other sites More sharing options...
