Emedia-Canada Posted December 11, 2002 Share Posted December 11, 2002 Quick question. I have to design a kiosk structure that has plasma screens which display moving images. What is the quickest way of incorporating .mov or .avi files into the material or scene? Thanks, DP Link to comment Share on other sites More sharing options...
quizzy Posted December 11, 2002 Share Posted December 11, 2002 just put avi's or quicktime's on the diffuse map...like this: Link to comment Share on other sites More sharing options...
nisus Posted December 11, 2002 Share Posted December 11, 2002 Hi Emedia, If you have memory problems I recommend you not to use *.mov or *.avi, but to use an image file list (*.ifl). This basicly a textfile that tells max which image from a sequence to load, so that per frame max only has to load one image instead of the whole animation into memory. As I said, this method can results in serious memory savings when your animationfile is rather large. Check the manual for more info on how to make *.ifl's: it's a real simple procedure and well worth it. rgds nisus Link to comment Share on other sites More sharing options...
Emedia-Canada Posted December 11, 2002 Author Share Posted December 11, 2002 Thanks guys, I appreciate your rapid response! Doug Link to comment Share on other sites More sharing options...
