BEKA Posted January 21, 2004 Share Posted January 21, 2004 Hi I have a question: After I got RPC demo and I install it on my comp. for 3d Studo Max, I can not run my plug-in. I got a message: "A valid Hardware Lock was not found". If anyone can tell me what is this message, and what I sould do ? I would appreciate it. thaks [ January 21, 2004, 11:40 AM: Message edited by: BEKA ] Link to comment Share on other sites More sharing options...
Jason Matthews Posted January 21, 2004 Share Posted January 21, 2004 The hardware lock is a piece of equipment that a program looks for before starting. It is mostly used when you purchase software for a time period. For instance, I got a copy of Form Z through the University of Florida. It came with a piece of hardware that plugs into the parallel port or USB port. Could you run Max before you installed rpc? If so, check with archvision to make sure you downloaded the right plugin. Let us know what they say. Thanks Link to comment Share on other sites More sharing options...
BEKA Posted January 22, 2004 Author Share Posted January 22, 2004 Yes I can run Max before and after I installed RPC, but when I open Max and try to use RPC I got that message. Anyway thank you for your help, and I will try to reinstall my software. Link to comment Share on other sites More sharing options...
Vince Paske Posted January 25, 2004 Share Posted January 25, 2004 What version of 3d Max are you using? Link to comment Share on other sites More sharing options...
quizzy Posted January 25, 2004 Share Posted January 25, 2004 Archvision has a wonderfull technical support where you can post your problems, they often respond within the hour..... post it there Link to comment Share on other sites More sharing options...
BEKA Posted January 26, 2004 Author Share Posted January 26, 2004 Thanks Link to comment Share on other sites More sharing options...
BEKA Posted February 6, 2004 Author Share Posted February 6, 2004 I use max 3.0 Thanks Link to comment Share on other sites More sharing options...
