helenistikyay Posted June 9, 2009 Share Posted June 9, 2009 hi everyone i need to do an animation about a picture a picture consists of mosaics and almost 10.000 of mosaic fall from sky and they must fall like rain as yo see pic below i started to draw mosaics one bye one then i'll try to assign the pic to all mosaics and use an UVW map but i have no idea how i will make them fall like rain 10.000 mosaics thanks for help Link to comment Share on other sites More sharing options...
Horhe Posted June 9, 2009 Share Posted June 9, 2009 Look into particle flow. Link to comment Share on other sites More sharing options...
helenistikyay Posted June 9, 2009 Author Share Posted June 9, 2009 i tought that too but, the mosaics places are set before i m trying to simulate a real mosaic work Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted June 9, 2009 Share Posted June 9, 2009 I think Neoscape has a script where windows fly into place on a building facade. Look for that, it may solve your problem easily. Then again, it may not. Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted June 9, 2009 Share Posted June 9, 2009 or look through allan mckays site, he has a little video tutorial on there somewhere about doing fractured ground with meshes via particle flow.. that'll get your tiles as particles, after that you could just float them away (backwards) Link to comment Share on other sites More sharing options...
helenistikyay Posted June 15, 2009 Author Share Posted June 15, 2009 this is what i did from till now 2500 mosaics and i need 10,000 more there has to be an easy way if anyone knows i really need help Link to comment Share on other sites More sharing options...
Dave Buckley Posted June 15, 2009 Share Posted June 15, 2009 not too sure, as already mentioned a complex particle setup would be the answer, but if you keep going then i've gotta hand it to you. you've got some extreme patience to get as far as you've got already Link to comment Share on other sites More sharing options...
helenistikyay Posted June 15, 2009 Author Share Posted June 15, 2009 this is the original mosaic as you see the mosaics shape is not equal Link to comment Share on other sites More sharing options...
anton Posted June 16, 2009 Share Posted June 16, 2009 (edited) You should try to make your life easier by choosing a camera angle or some well thought edits that would minimize the amount of work... If you don't have to have them perfect you can get that image in illustrator and try to vectorize it. It'll give you some shapes to play with. Also there is a script written by Bobo that would take an image and for each pixel it would create a box with a certain color assigned to it (don't remember the name of it but I can dig it up for you). For the rain, definitely a particles setup would be the best but you can also do that with a bit of scripting. What I would do is to animate a couple tiles falling the way you want it and then through maxscript you could just assign the animation to the rest of the tiles and randomly changing the start frame of the animation, giving the impression of rain. Another way to model this is by starting with 1x1 plane, convert it to editable poly then start shift dragging the edges to create new faces. Then select all the faces, inset them a tad and invert the selection and delete. That way you end up with just the right planes. Once you have that just map it and collapse the mapping then explode all the faces as single objects. Hope this helps! Edited June 16, 2009 by anton Link to comment Share on other sites More sharing options...
