MegaPixel Posted January 30, 2003 Share Posted January 30, 2003 Apperntly there is alot more to smoothing groups then meet the eye. I have the most difficult time with meshs that I create by attaching more then one element and I almost never get a smooth, continuous face. So I try to unify and normalize all normals, then autosmooth the entire mesh to see if that helps. Clicking on individual smooth group numbers doesn't seem to help me much. Can anyone offer some understanding to the whole smooth group concept and how to properly use them? Thanks for your time. Link to comment Share on other sites More sharing options...
John Dollus Posted January 30, 2003 Share Posted January 30, 2003 After you attach the elements, weld the vertices together. Link to comment Share on other sites More sharing options...
Guz Posted January 31, 2003 Share Posted January 31, 2003 The smoothing groups determines were the faces are smoothed. Foe example, you have a vase in low poly, and you want to apply a smoothed surface only where the neck of vase meets the vase's body. You select those faces and define a number in the smoothing group to these faces. So, if two faces share a common face with the same smoothing group number, they will render as a smoothed surface. Guz Link to comment Share on other sites More sharing options...
