thorsten hartmann Posted June 12, 2009 Share Posted June 12, 2009 (edited) Hi Guys, i have wrote a little Script for 3dsmax2010 and mental ray User. At 3dsmax2010 is the BitmapPager and Autolimit Mode as default "on". This is very good for Network Rendering (different Computer with different Ram) or 32Bit OS and Large Scene. For 64Bit OS and a Single Computer, can you optimize the Ram calculation. The trick is, i disable the Ram calculation Algorithmen. The rendering is 10% faster and you can work in a other Programm at the same time. Important is only, your scene need not more Ram as your Single Computer have. have fun mfg hot chip Edited June 12, 2009 by thorsten hartmann Link to comment Share on other sites More sharing options...
Trick Posted June 12, 2009 Share Posted June 12, 2009 Cute !! Sent AD the bill Link to comment Share on other sites More sharing options...
TheAllusionisst Posted June 12, 2009 Share Posted June 12, 2009 Thanks Thorsten! Will give it a try. Link to comment Share on other sites More sharing options...
thorsten hartmann Posted June 30, 2009 Author Share Posted June 30, 2009 Hi Guys, here the update of the Script. It is include: placeholder Object, conseerve memory, mr memory limit in MB, mental ray manages Maps have fun! mfg hot chip Link to comment Share on other sites More sharing options...
Dave Buckley Posted July 3, 2009 Share Posted July 3, 2009 has anyone used this yet. i have it, but i don't have a clue what i need to set or what each option actually does? i am using a 32-bit laptop, with max design 2010, with 3GB switch enabled. i would imagine i tick the 'single' button, as i am using single computer, but this then reads 'optimized for 64-bit' and even when i change between single and network, only a few options are different between the two settings, so what are the other options even there for Link to comment Share on other sites More sharing options...
thorsten hartmann Posted July 27, 2009 Author Share Posted July 27, 2009 Hi it give a new Verison of Ram-Optimizer V1.2, this have for all Parameters a Tooltip. I hope it is better to understand. mfg hot chip Link to comment Share on other sites More sharing options...
