displaying room volume in room tag
Dave Buckley
guys
i've been using revit for some time however never had to do this. I'm sure there is a simple setting somewhere.
i have my building, i then have a room, it contains a room tag etc.
i have also created a section view so that i can see the volume of the room (all set properly through the parameters)
i have also created a schedule with the volume field included, which is working and calculating the volume.
finally i have edited the room tag family that is being used, i have edited it so that the tag also includes a label for volume as well as area. However i can't get it to display the volume.
does anyone know how to get the volume of a room displayed in the room tag?
i believe i have done everything until this point correctly
do you want to PM me. I've solved my problem now. Not too sure what was causing it. I redid all the steps and it worked second time round? Weird
if you PM i can discuss the training with the practice in Wales.
I am actually a Revit Application Engineer working for an Autodesk Reseller and Revit Training is actually one of the services we offer.
if you PM the details then i can get in touch with them and get some training sorted.
I guess you do the visuals for them :)
it will make your job so much easier if they start to provide you with Revit models
