Edit Mesh OR Edit Poly modifiers?
RevitGary
If you have objects in your scene, maybe standard primitive, imported or xrefed objects. Then you decide you want to edit them.
What modifier do you add and why? I typically use edit mesh. I know edit poly is also very common for this purpose. Which is better and why? Does it matter?
If you choose either the Edit Poly modifier or convert the object to an editable poly, the poly objects have far more sofisticated tools to edit your model. I only use the edit polys. If I get an editable mesh, I always convert it an editable poly. Also, polys are faster than meshes. Hoe it helps. Good luck.
The Edit Mesh has a few things on the Edit Poly, most notably the 'Select Open Edges', which to me is invaluable.
Also, the Edit Mesh is a far better option for collapsing, as an Edit Mesh will consume far less RAM and file size. You can do a simple test to see. Take a 64 segment teapot, collapse to both types and see the result. The Edit Mesh version will be about 11MB and the Edit Poly will be about 18MB. The Edit Mesh will consume about half as much RAM.
You can always switch to Edit Poly whenever you want, but if you don't need to work on an object, I recommend saving as an Edit Mesh.
Like it's being said use the right one depending on the features you need.
I'm constantly going back and forth between the two when working on sites with uneven terrain. The select open edges that Brian mentioned is vital for creating curb paths out of cut roads and landscape. But then it's back to edit poly for the paint deformation and sculpting terrain.... and then once it's time for placing trees it's back to an edit mesh since the scripted object dropper I use (soulburn) for placing trees and people on sites doesn't recognize edit poly objects, but works fine for editable meshs.
My other big benefit out of edit poly is the make planer by axis, life saver.
Select open edges eh? Isn't that just the Border mode for edit poly? or is there some different workflow involved there that i'm not seeing.
border will only grab the single open edge that you select. With edit mesh when you say select open edges it grabs all your open "borders"
edit: hmmm just realized you can go into border mode and ctrl-A grab all the open edges. Okay they're pretty much the same then.
