Jdnelsen Posted June 16, 2009 Share Posted June 16, 2009 Hi all, I am trying to create a scene in 3d studio max and want to create an omni light, which I can do, but I cant figure out how to get the omni light source to actually show up as a ball of light...or for a spotlight, creating a ball of light in the can lighting in the ceiling. Any help would be great. If this doesnt make any sense please let me know and I will try to describe it better. Thanks everyone, Jon Nelsen jdnelsen@gmail.com Link to comment Share on other sites More sharing options...
anton Posted June 16, 2009 Share Posted June 16, 2009 It all depends on what rendering engine are you planning this for... If scanline then you'll fake it by adding an object that represents the light source's geometry with a self illuminated material and excluding it from the camera. This would also work in MR or Vray. If using Vray you can actually make that object be the light source. I am not sure if this works with MR though. Link to comment Share on other sites More sharing options...
dean@pikcells Posted June 16, 2009 Share Posted June 16, 2009 The omni light doesn't have any physical properties, you can't render it. you need to model the light source (ie a bulb) and give that some self illumination materials. Also try asking the in 3DS max section of this forum. Link to comment Share on other sites More sharing options...
Clanger Posted June 16, 2009 Share Posted June 16, 2009 If your using a Mental Ray light you have a check box to 'make light visible in render' then it just needs to be set to a sphere with the right radius, point light by default. Link to comment Share on other sites More sharing options...
WAcky Posted June 16, 2009 Share Posted June 16, 2009 Or you could add a glow post effect with max... Link to comment Share on other sites More sharing options...
