Devin Johnston Posted June 16, 2009 Share Posted June 16, 2009 We just installed Max 2010 on our farm but we left Max 2009 installed as well in case we needed to use it. Before we did the install everything was working but now none of the newly installed machines are showing up in BB. Could there be a conflict between Max 2009 & 2010 which is causing these machines to not show up? We are running the BB server as a service and I have confirmed that it is running. I've never seen this problem before, I'm hoping someone has some ideas. Link to comment Share on other sites More sharing options...
BrianKitts Posted June 16, 2009 Share Posted June 16, 2009 Have you upgraded backburner on your manager machine off the 2010 install disk so that they are all on the same version? Link to comment Share on other sites More sharing options...
Devin Johnston Posted June 16, 2009 Author Share Posted June 16, 2009 Yep they are all running the same version of BB. For some reason when we run the server as a service the machines won't show up but if we run it manually they do. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted June 16, 2009 Share Posted June 16, 2009 Maybe some help.... http://area.autodesk.com/forum/autodesk-3ds-max/lighting---rendering/backburner-server-service-not-registering/ Link to comment Share on other sites More sharing options...
ihabkal Posted June 16, 2009 Share Posted June 16, 2009 I think I can help you: go into each pc, run the server program, go to edit>settings, see if automatic search have been switched off. turn it back on, restart the server, the manager should find it now. if that works let me know. Link to comment Share on other sites More sharing options...
Devin Johnston Posted June 16, 2009 Author Share Posted June 16, 2009 Thanks Ihab but the link Travis posted did the trick, you've got to wonder who's beta testing this software if they don't pick up on a simple problem like this. Link to comment Share on other sites More sharing options...
