danb4026 Posted June 16, 2009 Share Posted June 16, 2009 (edited) I was sent some furniture files in the iges format. What do I need to do to convert to max? Edit: It looks like max 2010 can convert itself. It took some time and I had to convert the model to an Editable Poly after conversion, but it works. Edited June 16, 2009 by danb4026 found answer Link to comment Share on other sites More sharing options...
rmccoy Posted June 17, 2009 Share Posted June 17, 2009 Polytrans will convert the file formats. polytrans I had a similar situation happen a few months ago. I used the same process you described by just importing it into max and then cleaning it up. Link to comment Share on other sites More sharing options...
danb4026 Posted June 17, 2009 Author Share Posted June 17, 2009 Polytrans looks like a nice piece of software, but a bit more than I need. After I imported the file into max, I was able to clean it up and it worked out fine. It comes is a a nurb and is rather combersome, but once it was a poly, it was just fine, Link to comment Share on other sites More sharing options...
BrianKitts Posted June 17, 2009 Share Posted June 17, 2009 (edited) if this is just one time thing and you're looking to not have to make a purchase to get your model converted..... I had gotten a furniture model from the manufacturer in IGES and tried using the Rhino trial to convert out the file, can't remember what went wrong but I wasn't getting the results.... ended up using some random trial of a program I've never heard of called ironcad. worked like a charm to open up the IGES file, and export it as 3DS for max. Edited June 17, 2009 by BrianKitts Link to comment Share on other sites More sharing options...
danb4026 Posted June 17, 2009 Author Share Posted June 17, 2009 Great Brian....I will check out ironcad. Thanks for the info. Link to comment Share on other sites More sharing options...
