Sergio Posted November 12, 2003 Share Posted November 12, 2003 Hi guys, I am trying to boolean 7 cylinder and 5 spheres from box object. Am I asking 3DS Max 5 too much? Please if somebody can help me? I am quite behind because of that problem. BTW I am trying to model one very complicated sealing with dome and vaults. Regards Sergio! Link to comment Share on other sites More sharing options...
DelfoZ Posted November 12, 2003 Share Posted November 12, 2003 can u post a imagen before and after the boolean ? tnx.. Link to comment Share on other sites More sharing options...
skogskalle Posted November 12, 2003 Share Posted November 12, 2003 hey Sergio! If you have a chance to model the sealing in any other way - do it! MAX booleans suck, (they have allways sucked)thats the sad fact. (although I read somewhere that they have fixed them for r6, does anyone know?) anyways... I find that MAX sometimes does a better boolean job if you attach all your subtraction-objects together. That way you only do ONE boolean instead of 12... It doesnt allways work, but since MAX Booleans arent very logical, its worth a try. /K Link to comment Share on other sites More sharing options...
Archy@NJIT Posted November 12, 2003 Share Posted November 12, 2003 Alright, Yes unfortunatly Max 5 does not always deal with booleans in the best way. However they did cover for it in one way. If you boolean an object, then use the optimize command(can be found under modify). This will allow you an option control the number of faces of the object, as well as the Auto Edge option. Playing with these settings will allow you to avoid those jagged edges. YOu may need to optimize after every time you boolean. I know it doesnt seem like the most practical way to do things, but it actually helps a great deal. Best of Luck JM Link to comment Share on other sites More sharing options...
MegaPixel Posted November 12, 2003 Share Posted November 12, 2003 For what it's worth, MAX 6 seems to be rock solid with Booleans. I'm getting clean mesh results with no random faces. Link to comment Share on other sites More sharing options...
skogskalle Posted November 12, 2003 Share Posted November 12, 2003 "For what it's worth, MAX 6 seems to be rock solid with Booleans" sweet! too bad I cant afford r6... but its still good that they fixed it. I like booleans, but in r4 (which I use) theres simply too much trouble using them. Maybe they´ll release an update / bugfix for earlier max-versions too?? what do you think? Link to comment Share on other sites More sharing options...
Sergio Posted November 12, 2003 Author Share Posted November 12, 2003 Hi guys, thanx for all replys! Unfortunateli, max 6 is not any better for booleans, at least in my case. There is an image, green marks are surrounding areas where boolean was successful. Regards Sergio! Link to comment Share on other sites More sharing options...
skogskalle Posted November 13, 2003 Share Posted November 13, 2003 mmmkuy... are you sure you have actually lost your faces? maybe theyre just flipped? increase the segments on your box... I think it helps if all the faces are about the same size, and you have some pretty small stuff on you subtraction-objects. Link to comment Share on other sites More sharing options...
DelfoZ Posted November 13, 2003 Share Posted November 13, 2003 r u booloan 1 by 1 .. ?? ? Fisrt do what SKOGSKALLE saw " anyways... I find that MAX sometimes does a better boolean job if you attach all your subtraction-objects together. That way you only do ONE boolean instead of 12... It doesnt allways work, but since MAX Booleans arent very logical, its worth a try." Then do what SKOGSKALLE saw "increase the segments on your box" i think that have to work... Link to comment Share on other sites More sharing options...
recon Posted November 13, 2003 Share Posted November 13, 2003 From the looks of that picture, I'm guessing that the original objects were not completely closed, which can lead to problems. Can you post a max file of the two objects before the boolean operation? Link to comment Share on other sites More sharing options...
nisus Posted November 14, 2003 Share Posted November 14, 2003 Max and boolean operations don't go together well, unless sub-object boolean operations, which are great. Check out powerbooleans - Npower -for better boolean operations. rgds nisus Link to comment Share on other sites More sharing options...
Sergio Posted November 19, 2003 Author Share Posted November 19, 2003 Hi guys, thanx for your replyes! there is image before booleaning: Regards Sergio! Link to comment Share on other sites More sharing options...
Reitveld Posted November 23, 2003 Share Posted November 23, 2003 well, if you have access to autocad, it will handle your boolean with no problem. Then just import into max. Link to comment Share on other sites More sharing options...
