Brute Guy Posted June 18, 2009 Share Posted June 18, 2009 Hello All, Having some bizzare looking reflections in my chrome material, at first I thought it was just some undersampling in the material, but I still get this even if I pump up my material sub divs. I was initially using Brute Force as a secondary pass, changed to Light cache (which usually sorts this out) but still having problems. Any thoughts? Ta Marc Link to comment Share on other sites More sharing options...
cdgsean Posted June 18, 2009 Share Posted June 18, 2009 It looks like you have a map in the bump slot (ie. brushed steel) that hasn't been mapped on the object. Check to see if you have any mapping on the object, or just disable the map in the material slot. Hope this helps. Link to comment Share on other sites More sharing options...
Juan Altieri Posted June 18, 2009 Share Posted June 18, 2009 (edited) maybe a mapping problem.... if not, maybe a mesh problem, smooth or soemthing like this, can you post a wire? Edited June 18, 2009 by Juan Altieri Link to comment Share on other sites More sharing options...
Joseph Petrino Posted June 19, 2009 Share Posted June 19, 2009 My guess would be the HDRI file your using for reflection. Try rotating a bit or using another. Link to comment Share on other sites More sharing options...
Nic H Posted June 19, 2009 Share Posted June 19, 2009 bad mesh imo Link to comment Share on other sites More sharing options...
Brute Guy Posted June 22, 2009 Author Share Posted June 22, 2009 Hi all, It was a bad mesh afterall, Just cleaned it up in Rhino and re-imported and it was fine. Thanks for your comments. Marc Link to comment Share on other sites More sharing options...
