TomD_Arch Posted June 20, 2009 Share Posted June 20, 2009 O.K. I know someone asked about this before, but there didnt seem to be any answers to the issue. I am rendering with no global illumination, caustics or final gather. I have my environment map in the Mtl Edt mr Physical Sky set-up with some Output amount turned-up and some rpg turned up and it only happens when I am running the environment map, never when there is just mr Physical Sky. So one image shows what is happing when it is rendering, the other shows after I hit the cancel button and all the lines expand up and down. Help! Thank you. Link to comment Share on other sites More sharing options...
Stan Zaslavsky Posted June 21, 2009 Share Posted June 21, 2009 hey Thomas, So what's your question actually? try using some of the presets in final gather to get the problem worked out - you probably don't need GI for the exterior shot. hope it helps Link to comment Share on other sites More sharing options...
Justin Hunt Posted June 21, 2009 Share Posted June 21, 2009 The lines are a known bug, unfortunatly I dont have an answer. Do a search on CGTalk as I think there is a thread there covering this. jhv Link to comment Share on other sites More sharing options...
