MR exterior
sandiarch
Hi friends...
I am practicing this MR exterior rendering.
I have rendered this with MR sun and sky with low final gather value and 2 bounces.
MR SUN-1.1
MR SKY-1.5
not sure why this image looks with a blue tint..pls tell me how can i get rid of this bluish shade.
also is there any setting where i can change the color of MR SUN?
please help..thanks in advance.
I usually use this settings:
MR Sun:
Multiplier: 2
Red/Blue tint: 0,5
Mr Sky:
Multiplier: 4,5
Red/Blue tint: -0,35
Sometimes i change this settings a bit, but i think it gives a good environment color.
Hope i had given some little help.
Leave the multipliers at 1 to be accurate, to brighten the scene drop the EV value in exposure control.
The sun and sky colours are driven by the sun angle and changes as the angle changes. To alter the colour change the red/blue tint of either the sky and or the sun. Turn OFF "Inherit from sky" to do so.
You can also play with the white balance in exposure control.
jhv
jhv
+1
don't go changing multipliers of sun and sky.
You can use the regular skylight in the daylight system with a sky image to illuminate your scene. That could me much easier. You can also just do it in post. None of the sky models give you a quality sky out of the box... Vray or mental ray
Agreed to have background in post...BUT that is ok if we need final output as still images...
I wanna render the animation...in that case how can i do that in post.?
dont u think that it is better to have sky multiplier to higher side to get clear bright blue sky?
need more suggestions please....
ok, drag your physical sky from the environment into an empty slot in your material editor.
uncheck 'inherit from mrsky'
enable your viewport background to display the sky gradient
tweakt the red/blue values of the physical sky until it is the colour you want in the viewport.
depending on the version of max, you will also need to enable viewport lighting/shading/exposure etc to see the correct gradient in the background.
this way you get to keep the values of the sun and sky at 1, and you can still tweak the colours of the sky without affecting the actual sun and sky
By upping the multipliers of the sun sky causes more light to bounce around, blows out highlights, washes out mid tones and in general can lead to longer render times.
Use exposure control to brighten your images, thats what its for.
It is possible to control the backround in post when doing animations, render out the frames with an alpha channel and use After effects or even Photoshop CS3 to adjust. Same workflow as if your doing a still.
jhv
Thanks all of you for your inputs..they are really useful.
I could manage to adjust the sky color with red/blue tint (without disturbing the sun and sky multiplier)
I have attached updated image.
One more problem that i hv found with MR sun is...Ground/floor is receiving lot of light.brightness from MR sun...it doesnt look really good.. how can i get rid of this extra brightness for the ground/floor?
I know one option is to change the MR sun angle/time...but then that also changes the light/brightness on the building which i dont want.
Edited by sandiarch
If everything in your scene looks ok except the floor, then change the floor material.
thanks Mattclinch...i think u r correct...thats a better idea to change the color of floor textures..instead playing with other settings. :)
Here is the updated scene.
Again there is one problem here :) I can see some color bleeding right at the top walls above the entrance.. ..color of the roof is light green..and that color shade we can see on the walls...we can control this problem in V-Ray..how can we do that here in Mental Ray?
  • 4 weeks later...
As it has been said before fix it on post but you can also try changing the sky map under the environment map, I have done it before and it works fine. When it is said to fix it on post, it is meant that you save the picture with an alpha channel and change the sky map (which would be your alpha), as in get a nice sky from the web and put it as your sky (alpha channel). Hope this works out.
On the floor, try changing the floor material so it does not reflect so much sun or darken your map or something like that. It should be better once you do that.
