YOHKOH Posted June 22, 2009 Share Posted June 22, 2009 Hi all I cant seem to group imported objects. When I select all and go to group it is greyed out. If i group a single object i can then attach others to it, but this takes ages to do on every object. Is there any way round this?? Link to comment Share on other sites More sharing options...
RevitGary Posted June 23, 2009 Share Posted June 23, 2009 What kind of file are you importing? Link to comment Share on other sites More sharing options...
YOHKOH Posted June 25, 2009 Author Share Posted June 25, 2009 DWg from sketchup Link to comment Share on other sites More sharing options...
mfured20 Posted June 26, 2009 Share Posted June 26, 2009 When I have imported things from FormZ they sometimes come in as a frozen layer. Have you double checked that? I have also had issues where they come in, but the color is the exact same gray as the background and I just cant see them. This doesnt quite sound like your issue tho. Good Luck. Link to comment Share on other sites More sharing options...
YOHKOH Posted June 29, 2009 Author Share Posted June 29, 2009 Thanks for the replies guys. I dont think I was very clear in my first post. It is not the actual objects which are greyed out but the option to group them in group menu. Very frustrating. Seems to be anyhting that I bring through as a dwg from sketchup Link to comment Share on other sites More sharing options...
Bruce Hart Posted June 30, 2009 Share Posted June 30, 2009 Hi, a problem you could be having is that you have component items in Sketchup. These will translate into Instances with invisible Block Headers when you bring them into Max. Group will not work if you select something alone that has an associated block header as far as I know. You could try using the Drawing Link cleanup script that has been mentioned on this forum or make sure that everything is exploded (and purged) before you import into Max. Hope this helps Link to comment Share on other sites More sharing options...
BrianKitts Posted June 30, 2009 Share Posted June 30, 2009 what happens if you take the objects you have selected, right click and select "convert to editable mesh" then try to group them. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted June 30, 2009 Share Posted June 30, 2009 Hi, a problem you could be having is that you have component items in Sketchup. These will translate into Instances with invisible Block Headers when you bring them into Max. Group will not work if you select something alone that has an associated block header as far as I know. You could try using the Drawing Link cleanup script that has been mentioned on this forum or make sure that everything is exploded (and purged) before you import into Max. Hope this helps This was my thoughts also.... I use it frequently on geometry that won't group. It cleans it up, and removes the block/style references. http://www.scriptspot.com/3ds-max/dwg-cleanup . Link to comment Share on other sites More sharing options...
