Sargimo Posted June 25, 2009 Share Posted June 25, 2009 I lofted a shape around a spline and ended up with this. I'm just trying to figure out how to cap the hollow core. It is now an editable poly. thanks for any help, Josh (I remain online) Link to comment Share on other sites More sharing options...
Claudio Branch Posted June 25, 2009 Share Posted June 25, 2009 Select opposing edges and use the "Bridge" command...very fast and easy... Link to comment Share on other sites More sharing options...
Sargimo Posted June 25, 2009 Author Share Posted June 25, 2009 Hi Claudio, thanks for the fast reply. I tried it but I can't seem to get it to work. I also "looped" the inner edge and "bridged" but no luck. do I need to use the "settings"? Thanks, Josh Link to comment Share on other sites More sharing options...
Camby1298 Posted June 25, 2009 Share Posted June 25, 2009 Trace a line on the inner top lip of your wall (Using Snaps), convert to edible poly/mesh, then attach to the wall. That should work. Link to comment Share on other sites More sharing options...
Sargimo Posted June 25, 2009 Author Share Posted June 25, 2009 Hey Brian, That worked great, I did it again by Looping the inner edge and "creating shape from selection" Many thanks for pointing me in that direction, regards, Josh Link to comment Share on other sites More sharing options...
Claudio Branch Posted June 25, 2009 Share Posted June 25, 2009 If you are going to use Bridge, you need to select opposing sides with the ends left open. Otherwise, the second suggestion will also work... Link to comment Share on other sites More sharing options...
SandmanNinja Posted June 25, 2009 Share Posted June 25, 2009 You can also Bridge faces. I would have selected the inner Faces that were ..er.. facing each other and hit Bridge. I'm guessing that you did an Outline on the wall - if you do not have an inner wall, when you extrude the spline it will be a solid fill. Link to comment Share on other sites More sharing options...
Sargimo Posted June 26, 2009 Author Share Posted June 26, 2009 Very fast Joel thanks regards, Josh Link to comment Share on other sites More sharing options...
