Solideigratia Posted June 27, 2009 Share Posted June 27, 2009 Hello fellas, this is my first post in the forum. Am trying to apply textures to the plants from evermotion but so far i seem to be coming up short. Any good advice on how to proceed? Link to comment Share on other sites More sharing options...
Cad64 Posted June 27, 2009 Share Posted June 27, 2009 It would be helpful to know what program are you using? Link to comment Share on other sites More sharing options...
Solideigratia Posted June 27, 2009 Author Share Posted June 27, 2009 It would be helpful to know what program are you using? am using 3ds max 9 and vray Link to comment Share on other sites More sharing options...
Cad64 Posted June 27, 2009 Share Posted June 27, 2009 Ok, so are you trying to create your own new materials for the plants, or are you having trouble applying the default materials to the plants that you've inserted into your scene? I've been looking at the Evermotion website and it looks like the plants are provided in several different formats. Which file format are you inserting? Link to comment Share on other sites More sharing options...
Solideigratia Posted June 27, 2009 Author Share Posted June 27, 2009 Ok, so are you trying to create your own new materials for the plants, or are you having trouble applying the default materials to the plants that you've inserted into your scene? I've been looking at the Evermotion website and it looks like the plants are provided in several different formats. Which file format are you inserting? am having trouble applying the default materials. Am working with the vray versions of the objects. Link to comment Share on other sites More sharing options...
Cad64 Posted June 27, 2009 Share Posted June 27, 2009 Hmmmmm, I don't use Vray so I'm not familiar with that type of object. Do you have the plants and materials in your project work path, saved inside your project job folder, so that Max can see them? I generally save mine inside a folder called Plants inside my job folder. And as long as they have the .Max file extension, the materials always stay pathed to the plant. Do your Vray plants have the .Max extension, or is it something else? Link to comment Share on other sites More sharing options...
rishmantrijo Posted June 27, 2009 Share Posted June 27, 2009 I think evermotion plants has materials already applied with vray that is ready for rendering. Unless u need to change some texture from it. Link to comment Share on other sites More sharing options...
Solideigratia Posted June 27, 2009 Author Share Posted June 27, 2009 I think evermotion plants has materials already applied with vray that is ready for rendering. Unless u need to change some texture from it. thanks alot fellas. I got to the root of the problem, the plants are rendering like clockwork Link to comment Share on other sites More sharing options...
