Night Pool Lighting?
RevitGary
What have you tried?
I have done this successfully with mrPhotographic Exposure control (set to physical units), using photometric lights with an IES file resulting in ~700cd.
You could just find an IES file that gives an interesting light spread, then use the multiplier to get the intesity.
The pool's shell had an A&D material set to a nice plaster-ish white.
The pool water was a single sided. I believe the material started with an A&D preset Water - Reflective, then the diffuse was set to 0.1, refraction set to 0.9, IOR of 1.33. Under Advanced Rendering Options tab, Refraction Max distance set to the pool's depth, color at Max Distance set to a nice light blue.I probably tweaked the settings of the Ocean(lume) shader in the bump.
Look in the Samples files that come on the Max install disc.
Specifically here:
Samples\Scenes\Mental Ray\mr.sample.scenes\water.scenes\scenes
In the material editor of the file "Autodesk-water_types.max" wou will find 9 variations on water with the A&D shaders.
