multiple light
zewanil
I believe what you are trying to accomplish would be using instanced lights... when you copy the first light... use an instance copy... that way any changes you make to one, gets made to any instances with respect to intensity, color, etc...
thanks for replying ..
well exactly .. its to change the mood of my scene becaus i have like 30 halogen ... instance will make it identic but if i want to switch it off .. i will
have to do all separatly ...
i wonder if there is a way so i can group some light so i can swith them off with ONE switch ..
if you're using Vray there is an option to only use lights that are 'visible' in the viewport at any time, its pretty easy to have seperate lighting schemes set up that way by using layers.
Otherwise you can write a small 1line script in the maxscript listener (pink box in lower left hand corner)
--to shut all selected lights off at once:
$.on = off
--to turn all selected lights on at once:
$.on = on
You've already got your answer, make them instances. That way when you change/animate the intensity of one light all the other instances are affected. If you're using standard or photometric lights then instances are nicely grouped together in the light lister menu so you can easily change values in the way you wish.
Instancing is great if you want all aspects of the lights to be the same, however if you want different properties for different lights AND be able to control banks of lights instancing wont help.
Light lister was broken in 2009, there is a hotfix available.
jhv
Honestly, unless you're trying to do an animation (And even then, if the view is staying static, then you should simply render out the light sets seperately to a nice deep format like EXR or 48bit PNG's and Linear Dodge (Add) them together in photoshop, then you can just adjust the opacities/color tinting of each layer as you wish.
theres a script out there that does a lot of this for you for Vray/Mental ray.. and its something thats built into Maxwell. The script videos will show you all the ideas behind it, the script just makes the process a hell of alot easier than doing it by hand :)
Simple Scriptwise if you wanted to adjust multipliers for selected objects.. then say
--for all selected objects ($) the new light value will be = the current light value divided by 2
$.multiplier = $.multiplier / 2
to find out what a lot of these things are, you just turn on the maxscript listener, and in that little pink line it will show you the maxscript equiv for what you're doing in the UI (For most things) that doesn't always equal a script, but for simple stuff like this its super helpful.
Set the projector map on all your lights to some single convenient map. I have a gradient in my test scene here; doesn't take too much effort to set its colors to what I need (drag and drop color patches). Allows individual control over on, off, color, multiplier... all that lighting stuff. And then throws on a global filter.
I think Blur or somebody has a Solid Color map that would make it even easier.
