3dwannab Posted July 8, 2009 Share Posted July 8, 2009 As simply described in the title, Is there a way of showing the end result of the materials in the viewport like you see in the material editor, not just the diffuse but opacity maps etc. Or maybe i should have added this to the wish lists!! Thanks Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted July 8, 2009 Share Posted July 8, 2009 Yes, there is. It's called Active Shade. As a matter of fact, one of the "greatest" new features of Max 2010 is a new and improved version of the Active Shade (which has been around for at least 5 years, now). Link to comment Share on other sites More sharing options...
3dwannab Posted July 8, 2009 Author Share Posted July 8, 2009 i'm using max 2009 with vray sp2. I now active shade is in vray rt and might upgrade to that in near future until i see good report's. Is there anything i can do in this situation as active shade won't work with vray. Link to comment Share on other sites More sharing options...
SandmanNinja Posted July 8, 2009 Share Posted July 8, 2009 I think the vray rt is the thing you want. while I don't use vray, I've seen it on someone's computer and it's pretty cool. The scene sort of dissolves in over a few seconds and then it's there. Sort of rendered. Link to comment Share on other sites More sharing options...
amer abidi Posted July 8, 2009 Share Posted July 8, 2009 As simply described in the title, Is there a way of showing the end result of the materials in the viewport like you see in the material editor, not just the diffuse but opacity maps etc. Or maybe i should have added this to the wish lists!! Thanks well if i understand this correctly, then i think your solution is very simple. In the material editor, pick the material you want to show in the view port, and press the "show map in view port button" that looks like a checkered cube. This should show your materials depending on what hierarchy level you are at, so if you pick it at the top (root) level, it should show all maps including diffuse AND opacity together. But if its more you're looking for (like bump and translucency) then as the guys said, you'd have to seek max 2010 or third party plug ins like vray RT. Link to comment Share on other sites More sharing options...
3dwannab Posted July 8, 2009 Author Share Posted July 8, 2009 Yes vray RT would be good but i was hoping there was a something in-between. And the display all maps does not work at root of material (see attached) This material has an opacity map included unless its something to do with the fact its a .jpeg which doesn't have an alpha channel. Which file is best for opacity. I use the show map in viewport button which displays all maps (see attached) But if its more you're looking for (like bump and translucency) then as the guys said, you'd have to seek max 2010 or third party plug ins like vray RT.So does max 2010 with vray (not RT) display Active Shade? Can you change the settings on vray RT really low at the start and be able then to crank them up once to get down to finalising the project. Link to comment Share on other sites More sharing options...
