cutting the layer
paul ...maybe some one might know the answer to your query , but in the offchance that you dont get an answer i guess you will be better off asking this in After effects specific forum / cgtalk
You can't have two objects on one layer in AE, everything gets it's own layer, so there is no cut tool in AE.... that's premiere.
So for what are trying to do......
1. set the CTI at your "cut point"
2. press ctrl-D to duplicate your current track
3. hold shift and drag the outpoint of the primary track back to the CTI,
4. hold shift and drag the inpoint of the duplicate track forward to the CTI.
Edited by BrianKitts
  • 4 weeks later...
I think he's saying his video is too big for the composition. If that's the case you can either change the size of the space your working with through composition settings or you can go to transform for that particular layer and use the scale transform to shink down the source video inside the composition.
