Polygonal Lasso Region Render
Tim Saunders
I'm a huge fan of region rendering. Lots of times, there is a lot of stuff rendered in the rectangle region, that is not needed. It would be SUPERB, if you could hit region, and have a drop down selection type, marquee or lasso type, then just click-lasso your region.
  • 4 weeks later...
mentalray has "Subset of scene" in two froms,
First is a simple way to render selected objects only and is accable in the render dialogue
and the other is applied as a lense shader, you add object to a list and mr will automatically generate a mask around those object and output a render with an alpha chanel of that mask.
jhv
jhv
I have always considered the first fairly useless since it leaves horrible hallows, though maybe that is just in the render frame window.
The lens shader is very nice, though I wish it had more functionality. Like selecting groups, shapes, and such.
  • 2 weeks later...
Hmmm. Interesting, but seems time consuming. I could just do multiple region renders in the time to create a mask, place and size a plane with the opacity map on it.
I want the polygonal region render as explained.
Indeed it takes a while, but in some situations the (rather small) time investment is worth it (big renders, client that asks for a series of changes). Besides, once the setup is done, you only have to redraw the mask in Photoshop and that's it, really...
  • 4 weeks later...
+1 for the lasso region render. I've wanted this functionality for a while.
Nothing more annoying then having a piece of geometry that runs diagonally across your scene that has to be rendered with multiple regions.
It would be especially useful if you wanted to send that region off to the farm and only need to send it off once.
