fadi3d Posted July 9, 2009 Share Posted July 9, 2009 Hi Guys, Recently i noticed that importing Vray proxies (Chairs and Tables in a Restaurant) when rendered are bigger than when i exported them.does any of you know about this issue or has any info that could explain why ? thank you in advance and take care. fadi. Link to comment Share on other sites More sharing options...
WAcky Posted July 9, 2009 Share Posted July 9, 2009 Its probably some type of scaling issue when the proxy is created or perhaps a mismatch in unit setup. Did you create the proxys yourself? Link to comment Share on other sites More sharing options...
mervin_lim23 Posted July 9, 2009 Share Posted July 9, 2009 try to check your unit setup Link to comment Share on other sites More sharing options...
ihabkal Posted July 9, 2009 Share Posted July 9, 2009 Happens all the time in Lebanon, clients don't know what scale to use and they send files that are misscale. If you want wecan meet one day and I can show you some ways to keep the scale correct in between Autocad and Max. Link to comment Share on other sites More sharing options...
fadi3d Posted July 10, 2009 Author Share Posted July 10, 2009 Dear Friends, thank u all for ur answers the thing is i am sure my scale is wright and i do my proxies myself and they are file dependent (which is not ideal i know ) my table height was 76 cm with appropriate chairs i exported to Vray proxies and deleted the original. then i created a vray proxie and instanced it multiple times untill when i rendered i discovered i had to scale it down by 85% which is weird so what happened is what i'm trying to find out. Ihab i would like us to meet i admire ur work (you know where i am columbia center 7th floor ) take care guys and thanks again Link to comment Share on other sites More sharing options...
