Mia_material appears speckled in reflections. Maya and Mental ray
Chog Burley
hi all,
please can you help me!
on the attached image you can see some speckles where a white mia_material is reflected in other glossy surfaces.
the white mia is set to 'matte material' preset. if i change these objects to lambert the speckling goes away.
i have tried many options for the reflecting surfaces too with no luck.
the scene is lit with physical sun and portals on the main window.
using maya2009
many thanks,
CB
  • 6 months later...
I am having the same problem only more severe... The glass looks very speckled when view it from an eye level perspective. However, it looks fine when viewed from above. I have tried multiple glass materials, downloaded, mia, dielectric, all with the same problem. My hunch is that it is a problem with my render settings, and not the material, but i haven't been able to figure anything out. Any suggestions?
RevitGary - that link was very helpful, and i think that is a similar problem to mine. However, i am using mr for maya and that post is regarding mr for max (i think) so i wasn't sure what some of the stuff they were talking about was referring to. :confused:
Elevation - this particular glass that im using doesn't have the glossy samples slider, but i was using one earlier that did. I still had the same problem when i set the glossiness = 1 :(
I have have been tweaking my settings, its a little better, but i still have speckles. Can anyone see anything that i am missing/doing wrong?
Glass Mat:34461454.jpg
Render settings:
