How can I scale/rotate select position of the tetures?
How can I rotate and scale the tectures?
..I am new to Cinema XL R8.001 and when I insert images sometimes are out of scale...
Also I would like to know if it is possible to rotate the textures and select position of the them?? (e.g a graffiti texture on a brick wall)
...need heeeelp!!
thanx ! :)
Andronikos
[ January 11, 2004, 10:34 PM: Message edited by: Andronikos ]
Putting the graffiti on a wall is going to get a little more complicated. In all likelyhood, you will be stacking two seperate materials - one for the brick wall and one for the graffiti. There may additionally be others for posters, cracks, dirt and grime.
Apply the materials as described above but use an alpha channel in the graffiti material.
Hi! just make sure you have your texture tool selected (its the checkerboard to the left)
and just use your normal controls to move scale and rotate. or you could just use the atributes tab to the left and modify it from there. filepush.asp?file=ResizeofDibujo.jpg
