hsa Posted July 20, 2009 Share Posted July 20, 2009 I am VERY NEW to doing interiors and I am having a major problem with color bleed from red carpet on white walls. My lighting seems to be dialed in but I can't get that red bleeding to stop. I am using A&D materials but have no clue how to tweak either the white wall material or red carpet material to control the bleeding. I could use a ray type switcher but I can't get the A&D carpet material (which is very advanced) to combine with the switcher in the correct slots. Any ideas how to stop the bleeding? Link to comment Share on other sites More sharing options...
Clanger Posted July 20, 2009 Share Posted July 20, 2009 Colour bleed can be over the top if your not using a linear colour workflow with gamma corrected output. You can get all the info here: http://forums.cgsociety.org/showthread.php?f=2&t=610790 Link to comment Share on other sites More sharing options...
hsa Posted July 20, 2009 Author Share Posted July 20, 2009 Colour bleed can be over the top if your not using a linear colour workflow with gamma corrected output. You can get all the info here: http://forums.cgsociety.org/showthread.php?f=2&t=610790 My workflow is fine. If I could figure out how to add an A&D material to the ray type switcher all will be fine :-) Link to comment Share on other sites More sharing options...
Camby1298 Posted July 20, 2009 Share Posted July 20, 2009 Here ya go: http://jeffpatton.cgsociety.org/blog/archive/2008/1/ Link to comment Share on other sites More sharing options...
