properly closing a spline for extrusion?
huntch3
hi
Ive been drawing some shapes in cad, making sure that each one was a compltely closed polyline, and then importing it into max to extude....but sometimes the shapes can extrude a solid object and sometimes all I can extrude is the spline edge, but no solid object....all the vertices are welded and closed, and the shape is clean in cad...maybe could this mean that in cad two lines might be overlapping? is there an easy way to fix this without having to go back into cad and redrawing the the whole polyline? thanks for reading.....
I know this was the weird thing when you try to add modified to the spline. No form was created and no spline as well. All missing. Actually it not missing. This is the way I'm solve the problem.
Select that spline> vertex and go to selection rollout than hit show vertex numbers on display. Search no 1. If the vertex welded that mean two lines was overlapping and you must search and delete that overlapping line...;)
