mskin Posted July 22, 2009 Share Posted July 22, 2009 anyone know how to turn this back on? thanks Link to comment Share on other sites More sharing options...
sbrisson Posted July 22, 2009 Share Posted July 22, 2009 if it was in maya I would say: "save your scene\close maya\re-open" tadaaa.. I don't know if max is so unstable. Link to comment Share on other sites More sharing options...
RevitGary Posted July 22, 2009 Share Posted July 22, 2009 go to customize then revert to start up layout Link to comment Share on other sites More sharing options...
mskin Posted July 22, 2009 Author Share Posted July 22, 2009 thanks. Link to comment Share on other sites More sharing options...
luckymutt Posted July 22, 2009 Share Posted July 22, 2009 (edited) go to customize then revert to start up layout Although if you do that, you may lose other layout aspects if had any customized. close though Do: Customize->Show UI->Command Panel Or: Right-click on the tool bar -> Command Panel Edited July 22, 2009 by luckymutt Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted July 22, 2009 Share Posted July 22, 2009 throw a keyboard key onto 'Show Command Panel Toggle' for fun and profit. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted July 22, 2009 Share Posted July 22, 2009 go to customize then revert to start up layout On max 2009, there seems to be a bug regarding that. Sometimes, even if you reload the UI scheme, it does not show the command panel. If that's the case, simply exit and restart max. As far as I know, this bug is caused by an error in the ini file. This files stores, among other things, the position of each panel. For some reason, sometimes it assigns an off-screen coordinate, making max think the panel is there when it in fact isn't. Link to comment Share on other sites More sharing options...
wasteland giant Posted July 24, 2009 Share Posted July 24, 2009 Get this problem too. Its like really buggy and I don't know why it hasn't been fixed. Got this with most iterations of max too. But in 2009... there was a time when it wouldn't restore. if this continures to be a problem.. a) load default layout b) change the skin to a different version c) change it back. it will then bring back the panel. we really shouldn't have to do this though. Link to comment Share on other sites More sharing options...
SandmanNinja Posted July 24, 2009 Share Posted July 24, 2009 Yeah, that skin trick usually works Link to comment Share on other sites More sharing options...
