Macca23 Posted July 22, 2009 Share Posted July 22, 2009 Hi guys, Im re-rendering an older image now i have better skills and ideas. When its building the light cache though its coming out as i like it, then when it renders the image comes out really dark. Im using max and vray, ive got the colour mapping in the settings set to exponential, lighting using vray environment and vray sun with a vray physical camera. Image attached, thanks. Link to comment Share on other sites More sharing options...
Tim Nelson Posted July 22, 2009 Share Posted July 22, 2009 Uncheck 'exposure' in your camera settings and re-render. If it comes out really bright, then you know its just the exposure settings on your camera that need to be adjusted. If its the same, then its some other problem. Link to comment Share on other sites More sharing options...
Macca23 Posted July 22, 2009 Author Share Posted July 22, 2009 the image just went brighter but all the textures and everything were just bland, its still not right. I cant understand why? The settings are the same as ive used in other projects. Link to comment Share on other sites More sharing options...
Macca23 Posted July 24, 2009 Author Share Posted July 24, 2009 still no ideas anybody? I cant quite figure it out Link to comment Share on other sites More sharing options...
3D_IC Posted July 28, 2009 Share Posted July 28, 2009 I would say that your physical camera needs the f-stop changing. Also try changing the ISO. A balance of these two will brighten the image. Link to comment Share on other sites More sharing options...
Joseph Petrino Posted July 28, 2009 Share Posted July 28, 2009 Your say your revisiting an old image, so I would think you need to check "Legacy sun/sky/camera models" on the Global switches tab. Link to comment Share on other sites More sharing options...
Macca23 Posted July 31, 2009 Author Share Posted July 31, 2009 Hi again guys, none of these responses are working. If i light the scene using a normal camera and a vray light with no decay, its light enough, maybe a little too light, but as soon as i use a vray physical cam and vray sun with environment, it goes dark. Using the physical cam and sun in a different scene it works fine, its just this one? Link to comment Share on other sites More sharing options...
Tim Nelson Posted July 31, 2009 Share Posted July 31, 2009 Hard to say really. If its just this one scene thats a problem, I would suggest starting a brand new scene, and merging in everything from the old scene, minus the lights & cameras, & starting new. If you wanted to post a simple Max scene up here I could look at it to try to get to the bottom of it. You could delete most of the geometry in the scene, just leaving a few pieces for testing purposes. Link to comment Share on other sites More sharing options...
Christ1982 Posted August 25, 2010 Share Posted August 25, 2010 May be worth checking the Gamma/LUT settings, i've just had the same problems myself and found something in the VRAY forums to do with changing the gamma... Link to comment Share on other sites More sharing options...
