dynamic memory limit
fahtum
Its down to what memory you have on your computer. xp32 bit can only use up to 4gb ram while xp64 bit can use at lot more but im running 12gb with no problems with it set at 11gb.
So set that a little bit below your ram spec, this will help vray not crash by setting it to this limit.
Graphics cards have nothing to do with rendering an image, but only the viewport as you pan, zoom etc ) That's the job for it. CPU along with ram renders the image.
So your using max without a Vid card? Must be terribly slow within the viewport? :confused:
