3ds max advanced painter script
Macca23
Hey everyone,
i recently downloaded the advanced painter max script. Ive installed it successfully but could anyone tell me how to use it to scatter a tree across a plane for example? Or is there any decent tutorials on how to do it? Thanks in advance. Sorry if it seems a bit of a stupid question, ive just never used max scripts before.
1.Under Source in the Scatter Parameters push the "pick" button and then select the object you want to paint with. It should appear in the box.
2. Adjust Parameters as you see fit.
3. Select the object you want to paint on.
4. Click and drag and you should be painting.
There is a very good help document with this script you should have a look at it before you go any farther. Good luck.
