nino Posted July 28, 2009 Share Posted July 28, 2009 hi, im trying to reach a professional visualization, this is just last test render with little a bit corected levels, could you please try to comment this work and share your expirience what I should improve in this work? (i mean except moving people, ill put they there) thanks a lot Link to comment Share on other sites More sharing options...
Stephen Thomas Posted July 29, 2009 Share Posted July 29, 2009 Apart from being a bit of a strange scene visually speaking, I think the main thing you need to work on is your lighting. At the moment your image is very flat, meaning all surfaces have very similar illumination values. There is no sense of light and shadow to suggest where the light is coming from. These things help an image 'read' better and give a sense of depth and 3 dimensional quality. I suggest removing all unnecessary objects to allow you to do quicker test renders and tweak your lighting. How you do your lighting set-up will depend on the software you are using, but general approach is to keep it realistic i.e. put light sources in where they would be found in real life. Link to comment Share on other sites More sharing options...
nino Posted July 29, 2009 Author Share Posted July 29, 2009 i understand, okey ill try to do something with the lightning thank you Link to comment Share on other sites More sharing options...
nino Posted July 29, 2009 Author Share Posted July 29, 2009 and what about this way? :-) Link to comment Share on other sites More sharing options...
nino Posted July 30, 2009 Author Share Posted July 30, 2009 sorry for that last " cartoon " version....i think this one is better, do you have some ideas what i should improve to achieve more realistic render? thank you Link to comment Share on other sites More sharing options...
dogragurjeet Posted August 1, 2009 Share Posted August 1, 2009 you can try and decrease the overall ambient illumination a bit and tip up the sunlight streaming in from the windows. Furthermore there are very few interesting things in the shot. Try and add some more details to your models for example ceiling lights, maybe some furniture if it can be put there. You can also alter the materials a bit for example the flooring, try and make it a little more reflective. That would add drama. You are in the right path, just try and more contrast to the image and u will be there!!!! Link to comment Share on other sites More sharing options...
nino Posted August 1, 2009 Author Share Posted August 1, 2009 thanks for the tips ill fix it Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted August 1, 2009 Share Posted August 1, 2009 nino said: and what about this way? :-) This is the best of the bunch, I don't consider it cartoony. It is the most inviting, and leads my eye the most where it needs to go. Though de-saturating by about -7 to -9, and darkening the foreground would make it even better imo. Also, you need to delete the planter the is blocking part of the hands. It is breaking the line that is leading my eye to the hands, and then off to the left and up the stairs. Just delete it all together. Also, I think would try moving the target of the camera up a little, so you see less floor. Just make sure to keep the verticals straight. The light in the last one isn't horrible, but it also doesn't represent a space that I would go out of my way to walk through. Edit: And be careful wishing for realistic. Making things realistic is not always going to equal better results. Link to comment Share on other sites More sharing options...
Horhe Posted August 1, 2009 Share Posted August 1, 2009 Crazy Homeless Guy said: Edit: And be careful wishing for realistic. Making things realistic is not always going to equal better results. True. Link to comment Share on other sites More sharing options...
nino Posted August 1, 2009 Author Share Posted August 1, 2009 right....ill remember it....thank you. Link to comment Share on other sites More sharing options...
Dave Oliver Posted August 12, 2009 Share Posted August 12, 2009 there is nothing in the image that tells me what kind of space it is supposed to be. so its hard to say if the textures and scene objects are appropriate, or what kind of details you should be adding to make it look more realistic. clean details can add a lot of realism too. like where your wall texture changes, you would expect to see some kind of cover at the corner to hide the transition. if you want to work on lighting i would suggest starting with an all-white (or grayish) scene and getting the light the way you want before adding texture everything you do in a scene is usually driven by the idea behind the project, it is hard to make a 'generic' scene, because there would be no guide as to what should be in it. Link to comment Share on other sites More sharing options...
erickdt Posted August 12, 2009 Share Posted August 12, 2009 "Originally Posted by Crazy Homeless Guy Edit: And be careful wishing for realistic. Making things realistic is not always going to equal better results." My old boss used to say: "Our goal is not to necessarilly show (render) reality, our goal is to sell the sizzle on the steak." IOW: The goal of a rendering is to get the client excited and make them say to themselves "I simply must have that". Link to comment Share on other sites More sharing options...
