CINEMA 4D R8.5 AND SKETCH & TOON SHADER
STRAT
  • 3 weeks later...
Ernest - well, wadda think?
I'm still working on entering all those numbers Maxon sent me--first the temp serial numbers, then the permanent ones.
I have only fired up the program once or twice, click on a few things and ran back to Lightscape.
I am excited about learning the program, but I hate going back to being a rank beginner. I have been SO busy working I have not had any time for 'developement'--maybe in December. I will be done with all projects soon and won't be taking any new ones until I get really poor again (not that it ever takes very long).
OK, first Q: is there any other way to navigate in the viewports besides the little buttons on their titlebars? I am used to selecting a nav command and being able to click anywhere to operate it. It's weird being restricted to clicking those tiny icons.
Thank you for checking in on my progress!
Ernest,
There are three hotkeys that let you navigate the view anywhere in a given window.
Pan: 1+left click
Zoom: 2+left click
Rotate: 3+ left click
Each of these shortcuts can be customized. I know it's intimidating to start learning a new package, but I think you'll find yourself getting up to speed in a hurry. Good luck,
Jack
Actually Ernest, as long as you are using 8.2 or higher, and I asume you are, Cinema can use the common Alt+lm Alt+mm Alt+rm to navigate through the view ports. If that doesnt satisfy you, all commands can have custom key-binds by going to the window menu>>layout>>command manager.
Originally posted by Fernando Lino:
C4D use the same fRender engine..I know that is cheaper than 3d max...but I'd use 3d Viz and fr(total $2,100).
cebas developed both engines, but the two are entirely different. it is cheaper than max, but thats value for you, no indication that the quality is cheaper too!
and after using both for years i find c4d render quality much superior than viz/max imho :)
