danb4026 Posted August 1, 2009 Share Posted August 1, 2009 Every once in a while I run into a situation where objects will move, rotate, etc. a tremendous amount when I only want to move them a little. Once it starts, I have not been able to stop it from happening. Sometimes if I restart max the problem is resolved, sometimes not. I've tried resetting xform, making sure I am near 0,0,0...etc., but to no avail. What causes this crazy behavior and is there and easy fix? Link to comment Share on other sites More sharing options...
bev.lynn Posted August 1, 2009 Share Posted August 1, 2009 Dan, Have you un-checked Selection Sensitivity on the Viewport Configuration -> Steering Wheels tab? Link to comment Share on other sites More sharing options...
danb4026 Posted August 1, 2009 Author Share Posted August 1, 2009 Bev, It was checked....I just unchecked it. Not sure what that does, but we shall see. The problem is sporatic , but a real pain in the ars when it starts. Thanks for the tip. Link to comment Share on other sites More sharing options...
JonRashid Posted August 2, 2009 Share Posted August 2, 2009 Check how far your model is from the origin. Cad models sometimes have their origin miles away from the model. This results on all coord numbers being huge. As a result when they are rounded up or down accuracy is lost Link to comment Share on other sites More sharing options...
jinsley Posted October 30, 2009 Share Posted October 30, 2009 Dan, Have you un-checked Selection Sensitivity on the Viewport Configuration -> Steering Wheels tab? Bev, my hero... why does this happen? Happens on and off with me too. Especially when working with File Link Manager... Link to comment Share on other sites More sharing options...
TSuess Posted October 31, 2009 Share Posted October 31, 2009 It happens often when Autocad Files are linked. Esp if those models are created using blocks. Link to comment Share on other sites More sharing options...
