need script to work automatically
Dave Buckley
Guys
I'm importing geometry from Revit into Max, i always have the extra step of using an additional script to eliminate the triangulation that we get after the import.
I just wondered if there was anyway to automate the process so that whenever i import an FBX file, 3DS max runs the script automatically??
You could make the script work inside a file open callback (#filePostOpen most likely), so that once it's been evaluated, it will run automatically whenever a new file is opened.
Edited by KIT
Here's a quick whack at it. I couldn't find any way of knowing directly if the file being imported is a FBX file, so the script will run every time you import a file...
Just drag the file into the scene like before, now every time you import a file the script will find the new items on the scene and run the cleanup rutine. You will have to drop the script on the scene again if you restart MAX. I've set it up so it will output to the listener the mesh that it's being cleaned so you'll know if it's working properly. Let me know how it goes.
I'll see about creating a proper tool and mini GUI for this when I get some free time so you don't have to keep dropping the file to the scene every time max starts.
i think your my new hero
if i'm honest it's because when i'm doing presentations inside the software i often import revit models, and it just looks incredibly untidy with the additional triangulation.
so providing i get into my presentations early and run the script everything should be fine.
do i still need to select everything first on the initial first run?
Nop, the script will make sure the cleaning is done only on meshes that were just imported... in theory at least. Give it a couple of tries before you using it on a presentation just in case I messed up somewhere however. ;)
Good luck
