big_perm Posted August 6, 2009 Share Posted August 6, 2009 I've created a sandbox surface from imported CAD contours. Is there a tool that will help apply a jpeg of the aerial photo to the surface? I have tried importing the jpg as a texture but it only applies itself to 1 face at a time! Thanks Link to comment Share on other sites More sharing options...
danb4026 Posted August 6, 2009 Share Posted August 6, 2009 How is your sandbox surface modeled? Is it many faces? If so, do you have multiple material id's applied to it? A screenshot might be helpful. Link to comment Share on other sites More sharing options...
big_perm Posted August 6, 2009 Author Share Posted August 6, 2009 yes there are a lot of faces.... I am a bit of a newb to Sketchup, where are the material ID? Link to comment Share on other sites More sharing options...
cadmunkey Posted August 8, 2009 Share Posted August 8, 2009 You need to 'project' the texture onto the sandbox face. 1) file/import/(select your image) 2) click to place the image in the modelspace, and drag to resize accordingly (resize slightly larger than your sandbox terrain) 3) position the image above your terrain, face upwards (ie blue axis line perpendicular to the image face) 4) context click the image and 'explode' 5) context click/texture/projected 6) with the paint bucket tool selected, hold the "alt" key while clicking the image (this will sample the image) 7) release the "alt" key and use the paint bucket on your terrain. Link to comment Share on other sites More sharing options...
cadmunkey Posted August 8, 2009 Share Posted August 8, 2009 And if you get stuck following my instructions above I found this tutorial for you to follow: http://sketchup.google.com/3dwarehouse/details?mid=7b8a0bd3d848e985e523d8740930d7f9 Link to comment Share on other sites More sharing options...
