ezzor Posted August 12, 2009 Share Posted August 12, 2009 um as the Title says, im missing my transform/move axis, if u check the picture... dont know what ells to say Link to comment Share on other sites More sharing options...
trino Posted August 12, 2009 Share Posted August 12, 2009 press the "x" key. Link to comment Share on other sites More sharing options...
ezzor Posted August 12, 2009 Author Share Posted August 12, 2009 dosent work Link to comment Share on other sites More sharing options...
Stephen Thomas Posted August 12, 2009 Share Posted August 12, 2009 That's because you have keyboard shortcuts disabled. Unclick the button at the top that looks like a key with a letter T on it. Link to comment Share on other sites More sharing options...
ezzor Posted August 12, 2009 Author Share Posted August 12, 2009 dosent work either Link to comment Share on other sites More sharing options...
Stephen Thomas Posted August 12, 2009 Share Posted August 12, 2009 dosent work either Did you press X again after clicking off the keyboard shortcut button? If it still isn't working then go into Customize>Preferences and under Gizmos make sure Transform Gizmos is on and you may have to adjust the size if it turns out that they are there after all but just too small to see. Link to comment Share on other sites More sharing options...
ezzor Posted August 12, 2009 Author Share Posted August 12, 2009 has done as you said , (size:100), still nothing, (i do read very cearful*) =) Link to comment Share on other sites More sharing options...
jinsley Posted August 12, 2009 Share Posted August 12, 2009 I don't know why the other 2 suggestions didn't work... try going to: customize --> Gizmos --> turn on Transform Gizmos and any other options you wnat to see... edit: sorry... little too late! Link to comment Share on other sites More sharing options...
ezzor Posted August 12, 2009 Author Share Posted August 12, 2009 am i missing anything?? Link to comment Share on other sites More sharing options...
Dave Buckley Posted August 12, 2009 Share Posted August 12, 2009 go to your views menu, and make sure 'show transform gizmo' is checked, if that isn't checked then shortcuts will not make a difference and neither will the settings in your preferences Link to comment Share on other sites More sharing options...
ezzor Posted August 12, 2009 Author Share Posted August 12, 2009 go to your views menu, and make sure 'show transform gizmo' is checked, if that isn't checked then shortcuts will not make a difference and neither will the settings in your preferences Thx alot man , havent even notice xD cool, hope to cya guys arund Link to comment Share on other sites More sharing options...
