stee Posted August 13, 2009 Share Posted August 13, 2009 Hi, I did the following render as a means of learning v-ray and animation techniques. Any comments would be greatly appreciated.. Im still planning on adding people and some more objects, such as bins and more planting, to the scene... http://www.youtube.com/watch?v=5mwiymnShKY Watch in HD for best result Link to comment Share on other sites More sharing options...
jophus14 Posted August 13, 2009 Share Posted August 13, 2009 It looks great so far. Did you use a script to add the elements to the building? Keep posting updates. Link to comment Share on other sites More sharing options...
stee Posted August 13, 2009 Author Share Posted August 13, 2009 Thanks, i know nothing about scripts so no, didn't use them. I animated the ground floor glass all at once, and then selected each panel separately and moved the keys ahead 5 frames each. I then copied this group upwards to the above floors, selected all keys and moved them all ahead 10 frames per floor, so they would begin just after the floor below. It took forever!! I must look into scripts so Link to comment Share on other sites More sharing options...
Devin Johnston Posted August 13, 2009 Share Posted August 13, 2009 I like everything except for the end, there is to much contrast once the sun starts to set and you loose the building which is the focus of the animation. It would be better to have the sun set in the other direction behind the camera and have some lights come on inside the building. Link to comment Share on other sites More sharing options...
BrianKitts Posted August 13, 2009 Share Posted August 13, 2009 The shadows are quite harsh, I would play with your color mapping a bit to lighten up the heavy darkness. Link to comment Share on other sites More sharing options...
