thomasj Posted August 14, 2009 Share Posted August 14, 2009 hello, i imported a skp file into rhinoceros. it has noticeable faceting when rendering. Is there any way to make the model smoother? i tried tsplines but it wont accept this type of mesh. any help is appreciated cheers Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted August 18, 2009 Share Posted August 18, 2009 I poked around a bit and couldn't find anything. Looks like other people on the net have run into similar issues. Link to comment Share on other sites More sharing options...
rygoody Posted August 18, 2009 Share Posted August 18, 2009 I don't know about rhino specifically. But whenever you pull a sketchup model into 3DS max, the vertices are all unwelded. You always have to do a weld vertices on every object with a .001 tolerance and then setup the normals again. Maybe the rhino import is doing something similiar Link to comment Share on other sites More sharing options...
