Animate a roof opening
YOHKOH
Hi
I'm trying to do a simple animation of a roof flipping open. Like a jack in the box
However, I need to use one object for the box so need to animate the polygons. Is there a simple way to rotate the roof polygons around an axis.
When I try the axis is central to the polygon selection, so rotation does not occur around the hindge point
Ta very much
You have to move your gizmo to the desired pivot location. Go to the hierarchy panel (next to modifiers) click "affect pivot only" and move your gizmo to the desired location. Once you get out of the hierarchy panel, the new gizmo location will be where your object pivots from.
