Creationtwentytwo Posted August 17, 2009 Share Posted August 17, 2009 Hi there, I'm currently working on a project that involves large expanses of blue engineering bricks. And I've come across a problem I always run into on builds involving primarily bricks, and that is, how can one make it look more interesting? There are usually plenty of options I find to liven up a flat wall, IE dirt maps, ivy, minor variations in texture, but I'm having so much trouble making this one look good. I think it's due to the fact blue bricks have so much natural variation. Has anyone got any ideas as to what I could do to make it look a bit more appealing? Bearing in mind this is a Visualisation of a brand new build with very simple geometry. Many thanks. Link to comment Share on other sites More sharing options...
Aaron2004 Posted August 17, 2009 Share Posted August 17, 2009 Could you put taller vegetation in front of it casting shadows on the wall? The shadows could break up the monotony. Aaron Link to comment Share on other sites More sharing options...
Creationtwentytwo Posted August 17, 2009 Author Share Posted August 17, 2009 Ah that's a good idea, I suppose I hadn't considered using shadows. I will give it a try! Thanks again. Link to comment Share on other sites More sharing options...
Claudio Branch Posted August 17, 2009 Share Posted August 17, 2009 I have always found that a well-placed lens flare can liven up any boring shot. A flock of birds can help too... Link to comment Share on other sites More sharing options...
Creationtwentytwo Posted August 17, 2009 Author Share Posted August 17, 2009 Thanks for another great idea! Seems like there is hope! Thanks again. Link to comment Share on other sites More sharing options...
Horhe Posted August 17, 2009 Share Posted August 17, 2009 I have always found that a well-placed lens flare can liven up any boring shot. A flock of birds can help too... Claudio up to his tricks again... Link to comment Share on other sites More sharing options...
SandmanNinja Posted August 17, 2009 Share Posted August 17, 2009 A Flock of Seagulls...? Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted August 18, 2009 Share Posted August 18, 2009 Also, if you are into ZBrush, there's this semi-tutorial about making bricks that looks really awesome. http://zbrushcentral.com/zbc/showthread.php?t=069232 Link to comment Share on other sites More sharing options...
mattclinch Posted August 19, 2009 Share Posted August 19, 2009 Could you put taller vegetation in front of it casting shadows on the wall? The shadows could break up the monotony. Aaron "The Physician can bury his mistakes, but the Architect can only advise his client to plant vines" Frank Lloyd Wright Link to comment Share on other sites More sharing options...
GordonHo Posted August 19, 2009 Share Posted August 19, 2009 you could try to mix different noise maps together - perhaps as shaders to avoid tiling - and use them for displacement. it should give some irregularity into the bricks. the same can be done on the color slot, though it takes quite some tuning. of course adding more objects to the scene is another approach. you can enhance an image quite alot using different ps techniques. as well as placing trees and especially entourage people over the image. Link to comment Share on other sites More sharing options...
