Dave Buckley Posted August 18, 2009 Share Posted August 18, 2009 when i send a job to net render, the net render fails due to an object not having correct uvw co-ordinates, however, my scene is huge and i can't seem to find the object causing the crash. it's not as simple as typing the object name into the select by scene because things are grouped/x'ref'd etc etc Link to comment Share on other sites More sharing options...
Dave Buckley Posted August 18, 2009 Author Share Posted August 18, 2009 ok let's look at this a different way. when i render the scene locally i get an error message that pops up saying that a certain objects requires UVW coordinates. However, on a local render i have an option to ignore the error message and let it carry on rendering. Can i ignore the error message on a network render? Link to comment Share on other sites More sharing options...
Nic H Posted August 18, 2009 Share Posted August 18, 2009 yep you can ignore that error. use a script called 'Zorb' from scriptspot and you can select objects in scene that do / dont have certain modifiers. plus mass editing of modifers and loads of otehr stuff Link to comment Share on other sites More sharing options...
Dave Buckley Posted August 18, 2009 Author Share Posted August 18, 2009 i know i can ignore it locally but when i send the render to slaves i don't have the option to ignore it anywhere and the slaves just won't jump to the job Link to comment Share on other sites More sharing options...
SandmanNinja Posted August 18, 2009 Share Posted August 18, 2009 There must be a way to do this with a script... http://forums.cgsociety.org/archive/index.php/t-421353.html i=getClassInstances Missing_OSM o=for m in i collect (refs.dependents m)[3] select o would that do it? I'm shifting monitors around and only have 1 screen temporarily and max is opening in the 'Other' monitor (which isn't plugged in). I'll fix it up tomorrow tho. Need some power boards and what-not. Link to comment Share on other sites More sharing options...
Dave Buckley Posted August 18, 2009 Author Share Posted August 18, 2009 gonna give it a try now so thanks but ideally i want to take the other route (tell my servers to ignore any errors about missing mapping coordinates) Link to comment Share on other sites More sharing options...
