cjlopez4 Posted August 20, 2009 Share Posted August 20, 2009 I'm a making a transition to MR from Vray, I know vray has specific lights that work best (vray lights). Which lights are best suited for Mental Ray? Specifics: I have a hospital lobby that is anchored on either end with skylights and curtain walls, however the middle has no windows. I'm using MR Sun and Sky for the skylight and curtain wall areas. Which lights are best suited for the middle ground? Ceiling height ranges from 9-12' Link to comment Share on other sites More sharing options...
dagget20 Posted August 24, 2009 Share Posted August 24, 2009 You can either use them or mr area spot, mr omni even photometric have a good effect for mental ray. For the shadows use ray traced shadows and adjust the samples in its shadows parameters. Link to comment Share on other sites More sharing options...
nelpiper Posted August 26, 2009 Share Posted August 26, 2009 Insert a MR sky portal on every window you have. That's exactly what MR skies portals are for: to bring in illumination from a MR daylight system. Link to comment Share on other sites More sharing options...
Camby1298 Posted August 26, 2009 Share Posted August 26, 2009 Photometric lights are the best to use. With new updates mr have gone through, theyve been developed to render as close as photo real as mr can get. Add an IES profile to the lights and it will up the realism and the distribution of the light. Link to comment Share on other sites More sharing options...
