Can a kind soul help me open a .fbx file from Revit?
innerdream
I was sent a .fbx file (model) exported from Revit to give a bid, I use Modo and also have Cheetah 3D and neither program can open the file for some reason.
If I sent someone the file could you try to open it in 3D Studio Max and export as .3ds or .obj for me?
Thank you.
Thank you I'll take a look.
Looks like it's for turning into .fbx.
The Autodesk® FBX® SDK is a free, easy-to-use, C++ software development platform and API toolkit that allows application and content vendors to transfer existing content into the FBX format with minimal effort.
Not sure, but that sounds more complex than what I rememeber. Are you launching the UI version, or trying to accomplish it from command line?
I had the wrong download, I got it now. It didn't want to install on my Mac but I got it installed on the PC but it crashed on everything but .3ds format - no materials came through assigned unfortunately. Anyhow, I opened the file and it's enough to give them a bid so thank you.
