thomasj Posted August 28, 2009 Share Posted August 28, 2009 curious to see what everyone else uses out there. what is the best match (primary and secondary render engine) for a detailed rendering? what is the best match (primary and secondary render engine) in terms of speed? thanks Link to comment Share on other sites More sharing options...
Nic H Posted August 28, 2009 Share Posted August 28, 2009 detailed DMC/DMC fast IMAP/LC or a mixture of the 3. depends what you are after really Link to comment Share on other sites More sharing options...
Nic H Posted August 28, 2009 Share Posted August 28, 2009 except id never use DMC DMC, too slow. also never tried progressive path tracing either, might be worth a look. Link to comment Share on other sites More sharing options...
erickdt Posted August 28, 2009 Share Posted August 28, 2009 1st Bounce: Irradiance Map 2nd Bounce: Light Cache I use this combo in all situations.... Link to comment Share on other sites More sharing options...
danb4026 Posted August 28, 2009 Share Posted August 28, 2009 1st bounce irradiance map 2nd bounce Light Cache Link to comment Share on other sites More sharing options...
kippu Posted August 28, 2009 Share Posted August 28, 2009 same as above irrmap and LC Link to comment Share on other sites More sharing options...
idesign Posted August 28, 2009 Share Posted August 28, 2009 1st bounce irradiance map 2nd bounce Light Cache Link to comment Share on other sites More sharing options...
aaronrumple Posted August 28, 2009 Share Posted August 28, 2009 IR/LC 90% of the time. IR/Brute Force in some instances. Link to comment Share on other sites More sharing options...
mervin_lim23 Posted August 29, 2009 Share Posted August 29, 2009 in my case i normally use IR as 1st bounce and 2nd is LC.. sometimes i mixed them QMC for 1st and LC for 2nd.... Link to comment Share on other sites More sharing options...
martincg Posted August 29, 2009 Share Posted August 29, 2009 1./ IR + LC 2./ IR + QMC(brute force) 50% to 50% Link to comment Share on other sites More sharing options...
Brian Smith Posted August 29, 2009 Share Posted August 29, 2009 Although the irmap+lc combo is what I use 90% of the time for stills, a straight DMC+DMC is great for animations. We use Respower to render all animations and with their subscription program, you can render animations of any length for one low flat rate. In fact, for $260, you can render a limitless number of animations of any length and regardless of how long it takes to complete them...provided you submit the animations within 24 hours of purchasing. Because of this, you can bypass the need to render and upload large irmaps and lc files and bypass the need for the many settings that need to be experimented with for both. With the DMC, all you need to worry about is the Subdivs and Noise thresh, which is an easy set to figure out. Just upload the one file and render. You can even submit multiple jobs of the same scene while experimenting with different settings. As long as you don't mind the extra time to wait, it's worth it...especially when you get several hundred machines working on it at the same time. Progressive path tracing is also great, when speed isn't critical. You can even use it to clean up areas of a irmap/lc rendering that has too much noise or too little detail in certain areas. Link to comment Share on other sites More sharing options...
