first frame renders good then BAM!!
Koper
Oooi va voooi, problems problems problems:mad:
I'm rendering an animation and everything is set up good and renders perfectly, but only on my machine. On any other machine (localy and through backburner) it loads up the scene and renders fine for one frame (any frame in the sequence), then the next frames looks like an alpha map.
Now I know everything is set up good as it works on my machine.
Rendering through 8 vray cams and the only two that gives this problem is the two rendering with the vray fisheye camera enabled. This lets me believe that its something to do with the vray system or something. OR SOMETHING.:mad:
I checked the memory and it never exceeds 2,5GB so it cant be memory. Also, no texture maps are used thus its not missing maps
have anyone EVER seen this????:confused: phenomena
so i've figured out that the wrong renders look exactly the same as when I turn of the vray camera exposure. But again, it only goes for the camera's rendering with the fisheye lens.
Thus I think this might be a vray bug between the fisheye overide and the exposure tick.
nope, no exrefs were used
what we did was write a small little script to assign each frame in the timeline as a single frame job. that way every frame had to be re-loaded after completion in backburner. It Worked a charm
thanx for the suggestion.
