Importing AutoCAD DWG to MAX
Sharp007
Ok typically once I have posted a question, I figured it out. For anyone else who is struggling, you need to change the "MAXIMUM SURFACE DEVIATION FOR 3D SOLIDS" setup in the import options (see attached).
In my case I have set this to 0.1mm which gives me a nice curve.
Hi Gavin. I don't usually import CAD geometry into Max, as I do all my modelling in Max. However, I do import 2D DWGs to trace over and there are a few things worth checking to avoid faceting of curves. In the Import Options dialogue box, make sure you're importing with the correct units and you may have to tick "Rescale". Secondly, in the Import Options dialogue, ensure "Curve steps" is on 10. Finally, if the CAD model is created too far away from the origin 0,0,0 it can end up faceting curves when imported into Max, so it's best to move it to the origin in your CAD package before taking it into Max.
Hope that all makes sense and helps you to resolve your problems.
