Tim Saunders Posted September 2, 2009 Share Posted September 2, 2009 Sorry for the duplicate post, but I thought I would put this in the v-ray section as well, since I might be able to accomplish it based on v-ray settings. I'm wondering if anyone know how I can achieve this. I am hoping to animate a space developing from the ground-up. I thought i would be able to place a large box over the space that was invisible. The box could mask everything it over-laps, but as the box is moved up, you could see everything beneath it. The problem is, I want to see this happen from a view above the space, similar to the second image. The images below are obviously not the actual model, I just wanted to create some test. But I can't seem to make the box mask the objects it covers (physically), but still allow the camera to see the objects it is not physically covering. Obviously, once an objects has a matte/mask property, if it blocks the view of things behind it, they will be masked. Does this make sense at all? I guess another way to describe it would be like animated clipping planes. But only, the clip will be done on the scene's Z-axis, not the camera's. Any ideas? Link to comment Share on other sites More sharing options...
dean@pikcells Posted September 3, 2009 Share Posted September 3, 2009 so am i right in thinking that you want everything inside the box to be invisible to the camera, and everything else visable? Link to comment Share on other sites More sharing options...
Tim Saunders Posted September 3, 2009 Author Share Posted September 3, 2009 Yes. that's why I added the "well sort-of" to the title. Because in the true sense, the object is not a typical matte object, because it would still allow objects behind it to be seen. Link to comment Share on other sites More sharing options...
